RHEL 7.6 Installation - Missing ssl.conf file
  • hedgehog001
    • Jul 2020
    I am attempting an installation of Zabbix on RHEL 7.6. After installation, the ssl.conf file expected at /etc/httpd/conf.d/ssl.conf is unavailable.
    Is there a bug with this version of RHEL and Zabbix?
  • tim.mooney
    • Dec 2012
    • 1435
    Are you saying that installing Zabbix (what version? Using packages? Are they the official packages?) removed the file that RHEL 7.x conventionally uses for ssl configuration?
    What does
    rpm -qa | egrep 'zab|http|mod_' | sort
    output on this system?
    • hedgehog001
      hedgehog001 commented
      httpd-2.4.6-88.el7.x86_64
      httpd-tools-2.4.6-88.el7.x86_64
      http-parser-2.7.1-5.el7_4.x86_64
      zabbix-agent-4.0.6-1.el7.x86_64
      zabbix-server-pgsql-4.0.6-1.el7.x86_64
      zabbix-web-4.0.6-1.el7.noarch
      zabbix-web-pgsql-4.0.6-1.el7.noarch
    • hedgehog001
      Version 4.0. I believe everything is official packages.
