LDAPand Local auth
  • ognjen
    • Jan 2019
    • 23
    LDAPand Local auth
    Can Zabbix authenticate local and LDAP at the same time. If the user does not exist in a local DB try LDAP or the other way around first LDAP then local?
  • tim.mooney
    • Dec 2012
    • 1436
    I've wanted something like that too, but I don't think it's currently possible.
    My primary motivation is so that we can use LDAP authentication as the first try, but if there's a network partition and the web interface is isolated from any of our LDAP servers, have it fall back to using local auth. A monitoring system still needs to be accessible, even when parts of the network are (figuratively) on fire.
    We've essentially stuck with local auth to avoid that dependency.
    • csmall
      • Jun 2020
      • 70
      Fallback to local auth needs to be there.
      • ripperSK
        • Jul 2019
        • 42
        you can have local Auth and LDAP Auth active at the same time BUT:
        • single user cannot have both LDAP and local Auth enabled at the same time
        • LDAP users do not have passwords stored in the zabbix DB
        • there's no such thing as "fallback" meaning both of your authentication services - local + LDAP are active at the same time
        • you could have user "double" accounts as:
        • login - AD user
        • login_local - local user account
        To workaround this behavior you could setup an API call that will convert all of your LDAP accounts to local accounts if the LDAP server /Active Directory server becomes unreachable.
        zabbix USER API reference:
