Send notification until resolved
  • roberto.vizzini
    • Aug 2017
    I would like zabbix to send me an notification every hour until the problem is solved. How can I do it? Do I need to configure an escalation?
    Thank you.
  • tim.mooney
    • Dec 2012
    • 1436
    You could use an escalation, but for what you're trying to do it's probably not needed.
    You probably just need to set a 1 hour operational step for your action operation. See: https://www.zabbix.com/documentation...tion/operation
