Hi
I have recently installed a zabbix server V2.4.3 on centos 7 in my network and completed it's configuration,
now I have a remote network I want to monitor as well, located at a data center
I do not want to monitor the hosts there directly due to security issues, I wan to take advantage of the abilities provided by the proxy server,
I want to use the zabbix proxy as as a zabbix server as well so it will monitor the zabbix server I have to know if it stopped working.
so my questions are:
1. do I need to install the intended server as a zabbbix server and than add the zabbix proxy packages.
2. once zabbix server has been installed DB and all, will I need to install a separate DB for it's function as zabbix proxy or will it use the already existing DB.
3. do I create the data center hosts on both the zabbix proxy and zabbix server or just the zabbix server.
thanks in advance
thanks in advance
