Selecting historical data from zabbix 1.8 database
  • waardd
    • Aug 2014
    • 82
    I'm trying to select data from de zabbix database to export to a file for using in fr instance excel.
    But i get no historical data.
    I use Workbench to select data like so:
    select * from zabbix.hosts where host like 'lsrv1790%';
    This results in 10184
    select * from zabbix.items where hostid = '10184';
    I see all items and choose 41479
    select * from zabbix.history where itemid = '41479';
    This last one returns no rows. And i know for sure there must be data because i can see it in the zabbix graph.
    Where is my data gone to???
  • ingus.vilnis
    • Mar 2014
    • 908
    The historical data are kept in multiple tables depending on the item type (numeric, text, etc.)
    Check if historical values are in any of these tables:
    • history
    • history_uint
    • history_text
    • history_log
    • history_str
    • trends
    • trends_uint
    Best Regards,
    Ingus
    • waardd
      • Aug 2014
      • 82
      Tnx i found it in zabbix.history_uint
      Now i can make more extensive reports for management.
      • waardd
        • Aug 2014
        • 82
        Now a slightly different question.
        When i want this historical data from 1-1-205 00:00:00 to 31-1-2015 23:59:59, how do i select this.
        Clock format is Unix so i think vallues are:
        31-1-2015 23:59 3631884830
        1-1-2015 0:00 3629206431
        I thought like so:
        select * from zabbix.history_uint where itemid = '39276' AND clock > 3629206431 OR clock < 3631884830 ORDER BY clock DESC limit 2500
        But i think i'm making a basic mistake....
        • waardd
          • Aug 2014
          • 82
          Indeed a basic mistake
          select * from zabbix.history_uint where itemid = '39276' AND (clock > 3629206431 OR clock < 3631884830) ORDER BY clock DESC limit 2500
