In version 5 there are now overrides.
I'm using them and they are helpful for handling some things like whether to discover something and create an item or not or whether to enable or disable that item etc.
The challenge I am having is the overrides only seem to be good for newly added things. If I have 1000 Windows services discovered and items created in a enabled state for example and I want to change 80 specific ones to disabled, the override doesn't help here.
Is there a automated way similar to overrides that will update all the existing items that match the criteria for changes like this without me having to manually search for them all and change their config at the host level?
