Zabbix Agent Issue
  • Gokiwi64
    • Jun 2020
    • 36
    Zabbix Agent Issue
    Hi, Got a weird one with an agent running on a Linuxmint Ulyana install. Agent appears to be configured and installed correctly.
    sudo service zabbix-agent status
    ● zabbix-agent.service - Zabbix Agent
    Loaded: loaded (/lib/systemd/system/zabbix-agent.service; enabled; vendor preset: enabled)
    Active: active (running) since Mon 2020-07-20 17:51:59 BST; 8s ago
    Docs: man:zabbix_agentd
    Main PID: 50162 (zabbix_agentd)
    Tasks: 6 (limit: 9304)
    Memory: 3.7M
    CGroup: /system.slice/zabbix-agent.service
    ├─50162 /usr/sbin/zabbix_agentd --foreground
    ├─50175 /usr/sbin/zabbix_agentd: collector [idle 1 sec]
    ├─50176 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection]
    ├─50177 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection]
    ├─50178 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection]
    └─50179 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec]
    Jul 20 17:51:59 Hampton-Downs systemd[1]: Started Zabbix Agent.
    Jul 20 17:51:59 Hampton-Downs zabbix_agentd[50162]: Starting Zabbix Agent [Hampton-Downs]. Zabbix 4.0.17 (revision a528a0a4bc).
    Jul 20 17:51:59 Hampton-Downs zabbix_agentd[50162]: Press Ctrl+C to exit.
    But on the Zabbix server it stays "red" with the following error messages
    "Get value from agent failed: cannot connect to [[192.168.1.14]:10050]: [4] Interrupted system call"
    I cannot find any reference to this so wondering if someone can help ?
