Hi everyone
I'm still using version 3.4.15,
I got this trigger
{Template OS Windows:system.cpu.load[percpu,avg1].avg(5m)}>10
in this mode when trigger send email with url link I can see the line of trigger when is over 10 using this on operation: https://server/zabbix/history.php?ac...wgraph&itemids[]={ITEM.ID}
but now I can add other Item to get the info of cpu of the host when trigger is launched
so I added this in the same trigger
{Template OS Windows:system.cpu.load[percpu,avg1].avg(5m)}>10 and {Template OS Windows:system.cpu.num.now()}>0
now.. with that I get the cpu info and alert when load is over 10 but in the graphic... Don't draw the line of trigger like before... is an issue of version?.. or I need to fix in other way the message on action... ?
I test it using:
https://server/zabbix/history.php?ac...wgraph&itemids[]={ITEM.ID1}
https://server/zabbix/history.php?ac...wgraph&itemids[]={ITEM.ID2}
with no luck.. any idea ?
thx
I got this trigger
I test it using:
thx
