FYI : Zabbix V5 (nginx+MySql) / Raspbian Kernel v5.4.51 (20/07/2020) : fail
  • stephane.papin
    • Jun 2015
    • 22
    I've tried to install Zabbix server/agent on Raspberry Pi 4 with last kernel v5.4.51, fail (wget https://repo.zabbix.com/zabbix/5.0/d...buster_all.deb):
    N: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'http://repo.zabbix.com/zabbix/5.0/debian buster InRelease' doesn't support architecture 'armhf'
    Regards.
  • Atsushi
    • Aug 2013
    • 2028
    If you are using Raspbian, try using the repository for Raspbian.
    • HJ_SK
      HJ_SK commented
      An old thread but still the same problem when following the official procedure from :
      Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
      I'm on RPi5 with Raspbian OS Bookworm lite, latest version.
      This is the current message after sudo apt update :
      N: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'https://repo.zabbix.com/zabbix/7.0/raspbian bookworm InRelease' doesn't support architecture 'armhf'.
      Anybody idea what went wring here?
      And how to repair this?
      Thx in advantage!
  • zabbixuser39393
    • Jan 2021
    • 38
    I didn't care about it. Just did go with instructions and got installation to work
    • HJ_SK
      HJ_SK commented
      Yes I went also further, but disturbing me doing that. Meantime I find out that in the resopitory of zabbix is standing =all. That means that also armhf is included and tjat's not supported (anymore) by bookworm. I made an comment to that to zabbix-support to change that. So no more =all but something like =arm64. We'll see if it will be changed in the future.
