zabbix не стартует в логах не понятно
  • lewue
    • Jul 2020
    Приветствую!
    Перестал стартовать заббикс-сервер
    В логах :
     3757:20200726:150944.106 Starting Zabbix Server. Zabbix 4.4.6 (revision 8cc702429d).
    3757:20200726:150944.106 ****** Enabled features ******
    3757:20200726:150944.106 SNMP monitoring: YES
    3757:20200726:150944.106 IPMI monitoring: YES
    3757:20200726:150944.106 Web monitoring: YES
    3757:20200726:150944.106 VMware monitoring: YES
    3757:20200726:150944.106 SMTP authentication: YES
    3757:20200726:150944.106 ODBC: YES
    3757:20200726:150944.106 SSH support: YES
    3757:20200726:150944.106 IPv6 support: YES
    3757:20200726:150944.106 TLS support: YES
    3757:20200726:150944.106 ******************************
    3757:20200726:150944.106 using configuration file: /etc/zabbix/zabbix_server.conf
    3757:20200726:150944.114 current database version (mandatory/optional): 04040000/04040001
    3757:20200726:150944.114 required mandatory version: 04040000
    3757:20200726:150944.122 server #0 started [main process]
    3758:20200726:150944.122 server #1 started [configuration syncer #1]
    3758:20200726:150944.621 __mem_malloc: skipped 0 asked 24 skip_min 18446744073709551615 skip_max 0
    3758:20200726:150944.621 [file:dbconfig.c,line:94] __zbx_mem_realloc(): out of memory (requested 24 bytes)
    3758:20200726:150944.621 [file:dbconfig.c,line:94] __zbx_mem_realloc(): please increase CacheSize configuration parameter
    3758:20200726:150944.621 === memory statistics for configuration cache ===
    3758:20200726:150944.621 min chunk size: 18446744073709551615 bytes
    3758:20200726:150944.621 max chunk size: 0 bytes
    3758:20200726:150944.621 memory of total size 8388232 bytes fragmented into 72175 chunks
    3758:20200726:150944.621 of those, 0 bytes are in 0 free chunks
    3758:20200726:150944.621 of those, 7233448 bytes are in 72175 used chunks
    3758:20200726:150944.621 ================================
    3758:20200726:150944.621 === Backtrace: ===
    3758:20200726:150944.622 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x5558b78d102d]
    3758:20200726:150944.622 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x5558b78cc612]
    3758:20200726:150944.622 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x175b4a) [0x5558b7895b4a]
    3758:20200726:150944.622 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x180f9f) [0x5558b78a0f9f]
    3758:20200726:150944.622 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x1157) [0x5558b78a22fa]
    3758:20200726:150944.622 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x10c) [0x5558b776e419]
    3758:20200726:150944.622 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x5558b78debea]
    3758:20200726:150944.622 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x97d) [0x5558b7761434]
    3758:20200726:150944.622 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x5558b78d0818]
    3758:20200726:150944.622 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f5) [0x5558b7760ab5]
    3758:20200726:150944.622 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f0f21282873]
    3758:20200726:150944.622 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x5558b775fb7e]
    3757:20200726:150944.624 One child process died (PID:3758,exitcode/signal:1). Exiting ...
    3757:20200726:150944.626 syncing trend data...
    3757:20200726:150944.626 syncing trend data done
    3757:20200726:150944.626 Zabbix Server stopped. Zabbix 4.4.6 (revision 8cc702429d).
  • Hamardaban
    • May 2019
    • 2713
    вот это «please increase CacheSize configuration parameter» не наводит ни на какие мысли?
    • lewue
      • Jul 2020
      Подправил - помогло.
      Спасибо!
