Database error after upgrade to 5.0.2.
  • Rensjeh
    • Aug 2019
    Hi, I'm getting the following error after upgrading from 4.4.0 to 5.0.2.
    The frontend does not match Zabbix database. Current database version (mandatory/optional): 5000000/5000001. Required mandatory version: 4040000. Contact your system administrator.
Name:	2020-07-28 12_15_13-Warning [refreshed every 30 sec.].png
    I used https://www.zabbix.com/documentation...es/rhel_centos to upgrade Zabbix with my CentOS 7 client.
    In the /var/log/zabbix/zabbix_server.log the database should be version 05000000/05000001.
    27211:20200728:043721.923 completed 99% of database upgrade
    27211:20200728:043721.925 completed 100% of database upgrade
    27211:20200728:043721.925 database upgrade fully completed
    27211:20200728:043721.985 database is not upgraded to use double precision values
    5985:20200728:044307.651 current database version (mandatory/optional): 05000000/05000001
    What else can I check or do?
  • Hamardaban
    • May 2019
    • 2714
    You updated the server, but not the frontend.
    Zabbix frontend is written in PHP, so to run it a PHP supported webserver is needed. Installation is done by simply copying the PHP files from the ui directory to the webserver HTML documents directory.
    • Rensjeh
      • Aug 2019
      Indeed something went wrong with updating the front-end in combination with CentOS 7.
      If more people have this problem, here some fine documentation:
      Begin at step 10:
      https://bestmonitoringtools.com/upgr...ecision_values
      And this hero
      : https://www.youtube.com/watch?v=6A4JJHjUoTc
      • jorry
        • Aug 2021
        I solved this below ↓
        1. yum remove zabbix-web*
        2. mv /ui/* /opt/zabbix-backup/
        -> in case of me, /ui/ = /usr/shar/zabbix
        3. yum install zabbix-web zabbix-web-pgsql-scl
        remove current zabbix frontend packages -> clean the ui directory(backup or whaterver) -> reinstall zabbix frontend packages
        It will useful when "Required mandatory version" is lower than "Current database version".
        many thanks.
