All items turn red with an X
  • mystycs
    • Aug 2013
    • 56
    After a while of monitoring SNMP all my items in my template turn RED with an X and say the following message.
    SNMP error: (noSuchName) There is no such variable name in this MIB.
    Whats strange is that they work for a few minutes all the data comes in, then randomly it just turns them all off.
    Im trying to figure it out i looked at some packets, seems fine, and here below is the server log.
    What could be the issue here?
    PHP Code:
     7091:20150210:111837.059 server #24 started [escalator #1]
    7072:20150210:111837.108 housekeeper [deleted 0 hist/trends, 0 items, 0 events, 0 sessions, 0 alarms, 0 audit items in 0.054683 sec, idle 1 hour(s)]
    7085:20150210:112007.060 item "MBB TEST:cbAmuTemp" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbBucOutLevel" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbBucOutputPower" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbBucStatus" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbBucTemp" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbEsNo" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbHeading" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbLatitude" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbLongitude" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMaxEsNo" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMinEsNo" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbModemTemp" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotAngleAz" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotAngleEl" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotCurrentEl" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotSpeedAZ" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotSpeedEL" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbMotVoltage" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbRoll" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbRxPower" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbSatLongitude" became supported
      7085
    :20150210:112007.060 item "MBB TEST:cbSpeed" became supported
      7085
    :20150210:112007.060 error reason for "MBB TEST:cbWsAlarm" changed: Received value [] is not suitable for value type [Numeric (float)]
    7059:20150210:112512.152 SNMP agent item "cbMinEsNo" on host "MBB TEST" failed: first network error, wait for 15 seconds
      7064
    :20150210:112533.107 SNMP agent item "cbMaxRoll" on host "MBB TEST" failed: another network error, wait for 15 seconds
      7064
    :20150210:112554.147 SNMP agent item "cbModemTemp" on host "MBB TEST" failed: another network error, wait for 15 seconds
      7064
    :20150210:112615.579 temporarily disabling SNMP agent checks on host "MBB TEST": host unavailable
      7064
    :20150210:112821.948 enabling SNMP agent checks on host "MBB TEST": host became available
      7086
    :20150210:113007.130 item "MBB TEST:cbAmuTemp" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbBucOutLevel" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbBucOutputPower" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbBucStatus" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbBucTemp" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbEsNo" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbHeading" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbLatitude" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbLongitude" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMaxEsNo" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMaxRoll" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMinEsNo" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbModemTemp" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMotAngleAz" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMotAngleEl" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.130 item "MBB TEST:cbMotCurrentEl" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbMotSpeedAZ" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbMotSpeedEL" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbMotVoltage" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbRoll" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbRxPower" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbSatLongitude" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 item "MBB TEST:cbSpeed" became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB.
    7086:20150210:113007.131 error reason for "MBB TEST:cbWsAlarm" changed: SNMP error: (noSuchName) There is no such variable name in this MIB.
  • filipp.sudanov
    • May 2014
    • 137
    SNMP bulk requests are probably the reason - that is when several SNMP values are gathered in one connection. Unfortunately not all devices correctly support this.
    Support for bulk requests was introduced in zabbix 2.2.3. In 2.2.7 configuration parameter was added zabbix server to turn this off and in 2.4 is't configurable on per-host basis.
    • mystycs
      • Aug 2013
      • 56
      So would my best bet to be to setup the device to send requests back individually?
      Im using Zabbix 2.2.8
      • mystycs
        • Aug 2013
        • 56
        How do i go about disabling bulk requests?
        • filipp.sudanov
          • May 2014
          • 137
          What's your zabbix server version?
          • mystycs
            • Aug 2013
            • 56
            I put EnableSNMPBulkRequests=0 in my zabbix server conf.
            Was that the right thing to do?
            THanks
            • filipp.sudanov
              • May 2014
              • 137
              Yep, exactly the right thing to disable the bulk requests.
              • mystycs
                • Aug 2013
                • 56
                Awesome thanks!
