Zabbix mail not working
  • jackiebaron
    • Oct 2014
    • 17
    I'm sure this problem has been seen over and over but my case is a bit baffling. It all used to work. Basically I have created an item (existence of a test files) and also successfully created a trigger which fires when that file is deleted. I configured an email to be sent when the trigger fire but it doesn't send. The issue shows up in the "last 20 issues" pane but the action tab shows action (Gmail), Status (not sent). I can successfully send an email from the command line simply by typing sendmail [email protected] </file and it arrives. It just doesn't work from the zabbix engine and I get these messages in the /tmp/zabbix.server.log file:
    1164:20150211:121111.275 wrong answer on end of data [421 4.7.0 Email Senders Guidelines. u4si658062qcm.43 - gsmtp
    1164:20150211:121111.351 wrong answer on MAIL FROM [530 5.7.0 Must issue a STARTTLS command first. p21sm573254qgd.1 - gsmtp
    1164:20150211:121111.569 wrong answer on end of data [421 4.7.0 Email Senders Guidelines. z8si704447qas.9 - gsmtp
    1164:20150211:121111.782 wrong answer on end of data [421 4.7.0 Email Senders Guidelines. m1si668540qas.40 - gsmtp
    Any help or guidance would be greatly appreciated.
    thnx
  • filipp.sudanov
    • May 2014
    • 137
    Currently Zabbix does not support SMTP authentication. Please see https://support.zabbix.com/browse/ZBXNEXT-679.
    Gmail, as far as I know, does not accepts plain SMTP.
    Current workaround is to use a script media type and send email from that script.
    • jackiebaron
      • Oct 2014
      • 17
      Well can anybody show me how to send an email. It worked before. I just need to have an email sent when a trigger fires and the documentation seems quite scant. I create the trigger, it fire but the action is that the email is NOT sent. What can I check?
      • jan.garaj
        • Jan 2010
        • 506
        Script with TLS support: https://gist.github.com/superdaigo/3754055
