is zabbix_get included in 5.0?
  • charliecharliecharlie
    • Jun 2019
    The zabbix_get command is not working for me on a 5.0 install. Centos 8. I haven't tried to use it on previous versions so maybe I'm misunderstanding it's usage.
    returns
    -bash: zabbix_get: command not found
    For what it's work this manual page is blank: https://www.zabbix.com/documentation...ses/zabbix_get
  • tim.mooney
    • Dec 2012
    • 1436
    zabbix_get has been split off into a separate package. You need to install it separately, using your distro's package management tools.
      • Jun 2019
      Thanks Tim!
