I Need Help With Monitoring stackable switch.
  • ZabbixSon
    • Nov 2014
    • 17
    Hello there,
    Im running SLES11 SP2, using monitoring tool Zabbix 2.2.6, I would like to monitor 2 Cisco sg2000 switch(Stacked), but it have a same ip address, my question is
    1. How am i suppose to grab data from switch 1/port 1 and switch2/port1 ?
    2. If both switch have same ip address, it will occur conflict to my template right? because both switch 1/port 1 and switch2/port1 is on and i cant get any data from it using this(attachment)
    3.Should i grab port status using OID for stackable switch?
    4.if key = ifInOctets ,oid = 1.3.6.1.2.1.2.2.1.10.x , should i put x with switch port number? should i use 1.3.6.1.2.1.2.2.1.10.1/1 for SW1/g1 and 1.3.6.1.2.1.2.2.1.10.2/1 for SW2/g1 ?
    pleasee i need answer
  • eskytthe
    • May 2011
    • 363
    Normal the switces will appear as one (logical) unit.
    I would suggest that you use the "Template SNMP Device" template It will auto discover ports etc.
    BR
    Erik
    • ZabbixSon
      • Nov 2014
      • 17
      Hello Erik,
      Thanks for your reply, i've tried the "Template SNMP Device, but its not working. It unable to detect all switch2(24+4) + switch1(24+4) = 56 ports, only system name, device name and POE
      • eskytthe
        • May 2011
        • 363
        Sorry try to use "Template SNMP interfaces"
        If this do not work try to make an snmpwalk - it should provide you with the oid information you need:
        Hope this helps you.
        BR
        Erik
