I have been trying to create some items using XPath after reading this blog post: https://blog.zabbix.com/zabbix-xpath...ocessing/7936/
I created the HTTP agent item and it pulls in the XML data. I then started working a Dependent item and when I attempt to test the preprocessing, I get this error:
I assumed I was making a mistake because I am not familiar with XPath so I continued researching and testing for another hour or so before I accidentally saved the item and noticed it was working.
I installed Zabbix 5.0 on CentOS 8 from the Zabbix repo, is this an issue with my install or an issue with Zabbix itself?
cannot extract XML value with xpath "count(/server/devices/device/field)": cannot parse xml value
