I installed mysql 5.7 (8.0 was giving me errors, reinstalled fresh OS afterwards).
I followed these instructions exactly and on the fresh installation of Debian 10: https://www.zabbix.com/download?zabb...mysql&ws=nginx
If I go to http://SERVERIP/ it brings up the default nginx html template page
If I go to http://SERVERIP/zabbix it brings up the 404 not found.
Here is /var/log/zabbix/zabbix_server.log:
15632:20200801:151846.690 Starting Zabbix Server. Zabbix 5.0.2 (revision 352ca05870).
15632:20200801:151846.690 ****** Enabled features ******
15632:20200801:151846.690 SNMP monitoring: YES
15632:20200801:151846.690 IPMI monitoring: YES
15632:20200801:151846.690 Web monitoring: YES
15632:20200801:151846.690 VMware monitoring: YES
15632:20200801:151846.690 SMTP authentication: YES
15632:20200801:151846.690 ODBC: YES
15632:20200801:151846.690 SSH support: YES
15632:20200801:151846.690 IPv6 support: YES
15632:20200801:151846.690 TLS support: YES
15632:20200801:151846.690 ******************************
15632:20200801:151846.690 using configuration file: /etc/zabbix/zabbix_server.conf
15632:20200801:151846.691 current database version (mandatory/optional): 05000000/05000001
15632:20200801:151846.691 required mandatory version: 05000000
15632:20200801:151846.707 server #0 started [main process]
15641:20200801:151846.707 server #1 started [configuration syncer #1]
15656:20200801:151846.809 server #2 started [housekeeper #1]
15657:20200801:151846.810 server #3 started [timer #1]
15658:20200801:151846.810 server #4 started [http poller #1]
15659:20200801:151846.811 server #5 started [discoverer #1]
15661:20200801:151846.813 server #6 started [history syncer #1]
15663:20200801:151846.814 server #8 started [history syncer #3]
15665:20200801:151846.815 server #9 started [history syncer #4]
15667:20200801:151846.815 server #10 started [escalator #1]
15669:20200801:151846.816 server #11 started [proxy poller #1]
15672:20200801:151846.820 server #14 started [poller #1]
15670:20200801:151846.823 server #12 started [self-monitoring #1]
15674:20200801:151846.824 server #16 started [poller #3]
15676:20200801:151846.824 server #18 started [poller #5]
15671:20200801:151846.829 server #13 started [task manager #1]
15673:20200801:151846.829 server #15 started [poller #2]
15675:20200801:151846.829 server #17 started [poller #4]
15684:20200801:151846.830 server #23 started [trapper #4]
15681:20200801:151846.833 server #20 started [trapper #1]
15679:20200801:151846.833 server #19 started [unreachable poller #1]
15682:20200801:151846.835 server #21 started [trapper #2]
15683:20200801:151846.836 server #22 started [trapper #3]
15662:20200801:151846.836 server #7 started [history syncer #2]
15685:20200801:151846.837 server #24 started [trapper #5]
15691:20200801:151846.845 server #25 started [icmp pinger #1]
15693:20200801:151846.846 server #26 started [alert manager #1]
15694:20200801:151846.848 server #27 started [alerter #1]
15695:20200801:151846.848 server #28 started [alerter #2]
15700:20200801:151846.849 server #30 started [preprocessing manager #1]
15699:20200801:151846.850 server #29 started [alerter #3]
15701:20200801:151846.851 server #31 started [preprocessing worker #1]
15704:20200801:151846.852 server #33 started [preprocessing worker #3]
15707:20200801:151846.853 server #34 started [lld manager #1]
15708:20200801:151846.853 server #35 started [lld worker #1]
15702:20200801:151846.854 server #32 started [preprocessing worker #2]
15710:20200801:151846.854 server #36 started [lld worker #2]
15712:20200801:151846.854 server #37 started [alert syncer #1]
15663:20200801:151848.816 item "Zabbix server:zabbix[process,snmp trapper,avg,busy]" became not supported: No "snmp trapper" processes started.
15663:20200801:151848.816 item "Zabbix server:zabbix[process,ipmi manager,avg,busy]" became not supported: No "ipmi manager" processes started.
15662:20200801:151848.849 item "Zabbix server:zabbix[process,vmware collector,avg,busy]" became not supported: No "vmware collector" processes started.
15673:20200801:151854.857 enabling Zabbix agent checks on host "Zabbix server": host became available
15662:20200801:151855.903 item "Zabbix server:zabbix[vmware,buffer,pused]" became not supported: No "vmware collector" processes started.
15662:20200801:151942.209 item "Zabbix server:zabbix[process,ipmi poller,avg,busy]" became not supported: No "ipmi poller" processes started.
15662:20200801:151943.223 item "Zabbix server:zabbix[process,java poller,avg,busy]" became not supported: No "java poller" processes started.
I've followed the instructions, is there anything else I have to do to get into the front end?
Please advise.
Please advise.
