How configuration update on Passive Proxy work?
  • jonathan.vargas.cr
    • Dec 2014
    • 11
    On my setup, there is a Zabbix Server and a Passive Zabbix Proxy.
    I've noticed that the configuration data is not received very often to the Proxy, because when I do changes on Zabbix server configuration, items take a lot of time to start gathering data.
    I researched a bit and found that for Active Proxies, there is a confiuration property named "ConfigFrequency", but for Passive proxies I have the following questions I was unable to find:
    * How can I set the config update interval
    * How can I force a configuration update
    * Where is documented how these updates work?
    Thanks in advance.
  • ingus.vilnis
    • Mar 2014
    • 908
    If you are using passive proxies then the server sends the configuration changes to the proxy.
    The frequency is specified on the Server config file zabbix_server.conf.
    ProxyConfigFrequency=3600
    Unfortunately there is no way to force the config update for passive proxies.
    More references in Zabbix documentation here: https://www.zabbix.com/documentation.../zabbix_server
    Best Regards,
    Ingus
      • Dec 2014
      • 11
      Best Regards,
      Ingus
      Thank you so much
