I would like to know whether it is possible for an item to get a bit array.
Here is the MIB:
dts480xSysAlarms OBJECT-TYPE
SYNTAX DTSAlarm64 (SIZE(8))
DESCRIPTION "Alarm state of the DTS 4801 and 4802
Bit00=Alarm input 1
Bit01=Alarm input 2
Bit02=Alarm input 3
Bit03=Alarm input 4
Bit04=Error bit4
Bit05=DTS restart
Bit06=Failure 5V
Bit07=Supply voltage too low
Bit08=Line 1 current to high
Bit09=Wrong time zone line 1
Bit10=Wrong time zone DCF out
Bit11=Wrong time zone RS485 (only DTS 4801) /serial
Bit12=Error IRIG output
Bit13=Tele.-file invalid
Bit14=Program file invalid
Bit15=Wrong time zone switch
Bit16=Time source fail strat
Bit17=Time source fail TO
Bit18=No valid time
Bit19=NTP synch lost
Bit20=Error bit20
Bit21=NTP failed
Bit22=Wrong time zone DCF in
Bit23=Syn. only diff too big
Bit24=No mail server
Bit25=SNMP not running
Bit26=Error bit26
Bit27=Error bit27
Bit28=Line 2 current to high (only DTS 4802)
Bit29=Wrong time zone line 2 (only DTS 4802)
Bit30=Error bit30
Bit31=Error bit31
Bit32..Bit63=Error Device xx (only DTS 4801)"
REFERENCE "OFS_ALSTATE_ALARMS, 8, VARTYPE_BYTEARR"
::= { dts480xSystem 8 }
Is it possible to create an item for each bit separately? What is the easiest way to do it?
Here is the MIB:
Bit00=Alarm input 1
Bit01=Alarm input 2
Bit02=Alarm input 3
Bit03=Alarm input 4
Bit04=Error bit4
Bit05=DTS restart
Bit06=Failure 5V
Bit18=No valid time
Bit20=Error bit20
Bit21=NTP failed
Bit26=Error bit26
Bit27=Error bit27
Bit30=Error bit30
Bit31=Error bit31
