2.2.1 GUI password
  • coolpolo7676
    • Feb 2015
    2.2.1 GUI password
    Hi there, im using 2.2.1 and my previous admin has changed the web interface password, now i tried to change but cant, i have the root password, tried to look at the forums and videos, but things are different in mine, the .conf files are not there, the database is called Maria db. so things are different than forums, need help, urgent!
  • ingus.vilnis
    • Mar 2014
    • 908
    MariaDB is almost the same as MySQL.
    Make sure you can log into zabbix database from console.
    When opened Zabbix database, execute the command:
    update users set passwd = md5('newpassword') where alias = "username";
    Don't forget to change newpassword and username to correct ones.
    Best Regards,
    Ingus
