CPU load percentage
  • Villain
    • Aug 2006
    • 84
    CPU load percentage
    Is it possible to get the CPU load percentage, instead of a decimal value (0.01, etc.)?
    I would like to know if I'm using 10% of the CPU or 100% of the CPU, instead of the values that I am currently receiving. This would be similar to the Windows Task Manager value, only for the linux agent.
    Is there a key for this?
  • Villain
    • Aug 2006
    • 84
    nvm, I think I found it. Testing out: system.cpu.util[<cpu> <,type> <,mode>]
    • ravibhure
      • Aug 2008
      Petition for someone to fix the unix agents so we can get total cpu utilization
      in the meantime, you can create an item such as the following to get cpu usage:
      system.run[sar -P ALL 1 2 | grep 'Average.*all' | awk -F" " '{ print 100.0-$NF }']
      you have to enable remote commands on agent
      • bbrendon
        • Sep 2005
        • 873
        You can delete your system.cpu.load items and replace with this gem
        system.run[echo $((10#`cut -d' ' -f1 /proc/loadavg|tr -d .`/`grep -c processor /proc/cpuinfo`))]
        You're welcome. That'll be $110 (1 hr minimum)
        Unofficial Zabbix Expert
        Blog, Corporate Site
        • ittec
          • Mar 2008
          • 73
          Really?
          Hi
          Im really interested about last answer. Is this output of echo a trust feedback of what is happening at cpu level on linux machine?
          If is yes, is very good! Can someone confirm that?
          Thanks!
          • rue
            • May 2006
            • 43
            Originally posted by ittec
            Hi
            Thanks!
            Well, I'd say it's sort of interesting, but not quite correct (or I didn't get it ). Let's see:
            "cut -d' ' -f1 /proc/loadavg|tr -d ." will give you load average of the machine without decimal point, eg.: load of 1.29 will give you 129.
            "grep -c processor /proc/cpuinfo" will give you the number of processors installed.
            The rest is for calculating, so basically we have:
            result=(load without decimal point)/(number of processors)
            Hm, don't know, what exactly should be meassured with that... . Not CPU Usage I assume ... .
            I'd try sar, as mentioned above, but you need to enable sar (sysstat) on the machine you want to meassure on... .
            cheers
            Rü
            PS: this one worked for me on Ubuntu 8.10 Zabbix-Agent 1.6.4:
            as Userparameter: linux.cpu.usage,sar -P ALL 1 2 | grep 'Average.*all' | awk -F' ' '{ print 100.0-$NF }'
            • bbrendon
              • Sep 2005
              • 873
              What I posted is CPU load as a percent which was the original request.
              It uses bash to do the math conversion.
              • rue
                • May 2006
                • 43
                OK, my misconception was, that I assumed max CPU-Load could only be 100%. For reference: Load under UNIX is a bit more sophisticated than that and gives you a lot more details for capacity planing.
                For anybody interested: http://www.teamquest.com/resources/g...ay/5/index.htm
                Always nice to learn something
                cheers
                Rü
