[HOW] How I Create script in PHP and use in Zabbix?
  • velrino
    • Feb 2015
    Good morning
    I'm testing Zabbix , and would desaber how do I create a PHP script or Sheel Script ?
    Have to put in some folder ? Zabbix has the function to run automatically?
    My script
    PHP Code:
    #!/usr/bin/php
    <?php
    $used_space
    =chop(shell_exec("df -h / | grep -v Filesystem | awk '{print $5}'"));
    switch (
    $used_space) {
            case
    "$used_space" < "85%":
            print
    "OK - $used_space of disk space used.";
            exit(
    0);
            case
    "$used_space" == "85%":
            print
    "WARNING - $used_space of disk space used.";
            exit(
    1);
            case
    $used_space > "85%":
            print
    "CRITICAL - $used_space of disk space used.";
            exit(
    2);
            default:
            print
    "UNKNOWN - $used_space of disk space used.";
            exit(
    3);
