Data Overview showing variable instead of values
  • y4nn1ck
    • Aug 2020
    • 22
    Hello everyone, i've just upgraded Zabbix to 5.0.2, from 4.0 it's been working alright but i'm running into an issue.
    In my own dashboard, in a current or new Widget, i don't see the actual values, but i see the variable "ie : $2"
    Has anyone encountered such an issue?
    Thanks!
    - Yannick
  • Hamardaban
    • May 2019
    • 2714
    Use full macro name instead of $1, $2.
    • y4nn1ck
      • Aug 2020
      • 22
      Sorry i dont think i was clear enough...This is a built in widget from the Zabbix frontend, nothing i built myself... maybe i need to post this on the bug thread though
      • Hamardaban
        • May 2019
        • 2714
        Replace the positional macros in the template you are using with the corresponding full-name macros.
        https://www.zabbix.com/documentation...fig/items/item
        Note that the use of positional macros ($1,$2… $9 - referring to the first, second… ninth parameter of the item key) is now deprecated
        • y4nn1ck
          • Aug 2020
          • 22
          I understand what you are suggesting but as i said before, it's not an item i made myself, it's a widget for the Dashboard made by Zabbix...not sure how i can modify that.
          I found the error!!!! In the database, the item created for that Data Overview of the Zabbix server has been wrote with the $4 and $2 value :
          mysql> select * from items where itemid=23328 \G
          *************************** 1. row ***************************
          itemid: 23328
          type: 5
          snmp_oid:
          hostid: 10084
          name: Zabbix $4 $2 processes, in %
          key_: zabbix[process,vmware collector,avg,busy]
          So basically what i did was to update the template used for Zabbix : Template_App_Zabbix_Server-4.2.0.xml from thee official webpage : https://www.zabbix.org/wiki/Zabbix_T...cial_Templates
          All is good now!
          • eithor
            • May 2020
            • 50
            Note that after upgrade from 4.x to 5.x you should do a manual import of all provided templates (from source/git) as this is not done automatically.
            • y4nn1ck
              • Aug 2020
              • 22
              That's very good to know...and i hope Zabbix improve this as far as official template goes.
              • y4nn1ck
                • Aug 2020
                • 22
                Good point
