How to filter triggers from Dashboard?
  • SkautsLV
    • Aug 2020
    Hello.
    I just setup my 1st Zabbix setup to monitor around 20 HP Switches, everything is self explanatory this far but now I have stuck on problem with switches having too much triggers.
    I added all my switches using "Template Net HP Enterprise Switch SNMP" which has like only 8 triggers inside it and from what I found there, they are the ones I need.
    But problem is that when I added switches, it discovered around 150-250 triggers on each one of switches and I can not find any way to filter Main Dashboard "Problems" widget to only notify me about the 8 triggers from template. Any help will be appreciated.
  • batchen_regev
    • Aug 2018
    • 80
    Go to the template "Template Net HP Enterprise Switch SNMP" you have there except of items and triggers - discovery
    see what you need and waht you dont and just disable discovery roles you dont need.
