Monitor Zabbix Proxy Time Difference
  • GaryBarber
    • Jan 2020
    • 13
    I recently had a problem with items queuing on the proxy. In the end the problem was actually that the time on the zabbix proxy server was 32 seconds behind the time on the zabbix primary.
    I recently saw a template that would monitor the time difference between proxy and primary, but now I can't find it. Can anyone post the link to that info or tell me how to achieve this please?
  • Hamardaban
    • May 2019
    • 2713
    zabbix[proxy,<name>,<param>]
    Information about Zabbix proxy. Integer. name: proxy name
    Valid values for param are:
    lastaccess - timestamp of last heart beat message received from proxy
    delay - how long collected values are unsent, calculated as "proxy delay" (difference between the current proxy time and the timestamp of the oldest unsent value on proxy) + ("current server time" - "proxy lastaccess")
    Example:
    ⇒ zabbix[proxy,"Germany",lastaccess]
    fuzzytime() trigger function can be used to check availability of proxies.
    This item is always processed by Zabbix server regardless of host lo
