I simply need to add 0.7 to a returned value in preprocessing, however it seems that javascript is taking 0.7 as a string and converting the whole result to a string.
If I do:
return value+0.7
or any formatting variation of that I've tried, using a test value of 26, it will result in 260.7
Upon testing this further, it seems that using almost exactly the same formula as the documentation shows, any simple addition is converted to a string.
i.e. return (value - 32) will return the correct figure such as 0 for a test value of 32
However, addition is broken.
return (value + 32) will result in 3232
If I do:
return value+0.7
