Hi all,
I obtained an issue with the template Template DB MSSQL by ODBC on Zabbix 5.0.2 and SQL server Microsoft SQL Server 2016.
I get the error message: Preprocessing failed for: [{"object_name":"MSSQL$MSSQLS2016:Access Methods","counter_name":"AU cleanup batches/sec","instan...
1. Failed: cannot extract value from json by path "$[?(@.object_name=='MSSQLS2016:SQL Statistics' && @.counter_name=='Auto-Param Attempts/sec')].cntr_value.first()": no data matches the specified path
I cannot understand the root cause of this issue and only this item "MSSQL: Get performance counters" doesn't work.
I tried to follow this topic but I don't find the information noticed https://www.zabbix.com/forum/zabbix-...alue-from-json.
Could you please help me?
Thank you!
Thank you!
