Monitor linux SYSV semaphore?
  • aschild
    • Sep 2014
    • 25
    We have a application which does sometime leak semaphores.
    Every ~100 days, we see this error on the server:
    Insufficient system resources - failed to allocate a SYSV semaphore
    Is there a way to monitor such SYSV semaphores in linux?
  • jan.garaj
    • Jan 2010
    • 506
    Convert output from
    ipcs -s
    to required Zabbix metric by using UserParameter.
    • aschild
      • Sep 2014
      • 25
      Originally posted by jan.garaj
      Convert output from
      ipcs -s
      https://www.zabbix.com/documentation...userparameters
      Yep,
      but this only lists the semaphores,
      we will then need to look inside the semaphores and the number of free slots on certain semaphores.
      ipcs -s
      to list all semaphores, then
      ipcs -s -i <id>
      to list the slots per semaphore and finally look how many are free or used up.
      This is where I'm currently struggling...
      • jan.garaj
        • Jan 2010
        • 506
        I'm lost. Please define metrics (items), which do you need to monitor. "I need semaphore monitoring" is vague definition.
        • aschild
          • Sep 2014
          • 25
          We have a process which has dbsrv11 as name.
          From this one I can get the PID it is running under, lets say it's PID 1911.
          In the list of sempahore (ipcs -s), I see about 30 semaphores
          When I then inspect each of these via ipcs -s -i <id>, I receive such tables:
          Semaphore Array semid=11534409
          uid=0    gid=0   cuid=0  cgid=0
          mode=0777, access_perms=0777
          nsems = 250
          otime = Mon Feb  2 05:24:40 2015
          ctime = Mon Feb  2 05:24:44 2015
          semnum     value      ncount     zcount     pid
          0          1          0          0          1911
          1          1          0          0          1911
          2          1          0          0          1911
          3          1          0          0          1911
          4          1          0          0          1911
          5          1          0          0          1911
          6          1          0          0          1911
          7          1          0          0          1911
          8          1          0          0          1911
          9          1          0          0          1911
          10         1          0          0          1911
          11         1          0          0          1911
          12         1          0          0          1911
          13         1          0          0          1911
          14         1          0          0          1911
          15         1          0          0          1911
          16         1          0          0          1911
          17         1          0          0          1911
          18         1          0          0          1911
          19         1          0          0          1911
          20         1          0          0          1911
          21         1          0          0          1911
          199        1          0          0          1911
          200        1          0          0          1911
          201        1          0          0          1911
          202        0          0          0          0
          203        0          0          0          0
          204        0          0          0          0
          246        0          0          0          0
          247        0          0          0          0
          248        0          0          0          0
          249        0          0          0          0
          As you see in the example above, the semaphore 11534409 has 250 slots,
          of which currently 201 are used up.
          I would need to get notified, when the slots are used up 80%.
          So the step to monitor would be:
          1. Get the PID of the dbsrv11 process
          2. Find all semaphores which are used by PID (There are usually many of them)
          3. In these semaphores, look if there are still 20% free slots
          Sound like a task for some bash wizard...
          • jan.garaj
            • Jan 2010
            • 506
            Proper Zabbix monitoring solution:
            Zabbix LLD discovery which return semaphore id and related process name of this semaphore ID. Then you can filter which processes do you want to monitor in zabbix by using regexp and for these semaphore IDs will be created metric (item) "Semaphore utilization" and trigger, which raise event problem if metric value will more than defined threshold. And then event will be transformed into action (email, jabber message, ...)
            Is it complicated? Yes, but it's proper (Zabbix) monitoring concept: item -> trigger -> event -> action.
            But you are talking only about notification. So IMHO you need only bash script, which will send analyze/calculate/evaluate (create alert email) everything in one go. To be honest I don't see any advantage to use Zabbix for this task for you. It'll be easier for you to create just this one (probably) bash script :-)
