Run sql query for MSSQL Databases
  • benzer
    • Aug 2020
    I am new to zabbix and I am trying to create an Item with "Database monitor" type.
    On the Server there is Version 5.0.2 installed and on the Host Agent Version 5.0.2. So Active Checks are running well.
    ODBC Driver is also installed on the Zabbix server:
    --> /etc/odbcinst.ini
     [ODBC Driver 17 for SQL Server]
    Description=Microsoft ODBC Driver 17 for SQL Server
    Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.6.so.1.1
    UsageCount=1
    Now which "Database driver" is needed for data source definition?
    --> /etc/odbc.ini
    [test]
    Description = MSSQL test
    Database Driver = ??
    Server = 127.0.0.1
    User = xxx
    Password = xxx
    Port = 143
    Thank you
