No connection between Zabbix server and agent
  • TapioKoistinen
    • Aug 2020
    We are getting error message -> active check configuration update from [192.168.92.8:10051] started to fail (cannot connect to [[192.168.92.8]:10051]: [4] Interrupted system call)
    System has following versions
    OPNSense os-zabbix agent
    OPNsense 20.1.9-amd64
    FreeBSD 11.2-RELEASE-p20-HBSD
    OpenSSL 1.1.1g 21 Apr 2020
    and Zabbix server is 5.0.2
    What could cause connection problem?
  • LenR
    • Sep 2009
    • 1011
    Network or firewall blocks are the usual problem. On the server, issue: netstat -an | grep 10051, ensure that it shows as LISTEN on *.* or your desired nic. Install nmap or similar tool on the agent, then from the agent: nmap -P0 -p 10051 192.268.92.8
    These ensure that the server is listening on 10051 and that the client system can see that port, not using any Zabbix parts.
    Also selinux.....
    • Singularity
      • Aug 2020
      • 81
      Can you connect from zabbix server to zabbix agent using telnet <zabbix_agent_host_ip> <zabbix_agent_port>. If yes, make sure that ActiveServer value in zabbix_agentd.conf file is set to zabbix_server_ip.
