Zabbix multiple steps to monitor service
  • WhsJcp
    • Jun 2020
    Hi all, I am still very new to Zabbix so I apologize if the question is not explained as good as I would like to.
    I want to monitor a service that exposes APIs, however the value I want to check are presented only after a login to the same APIs.
    Is it possible (and if so, how) to have Zabbix login to this service and then retrieve a JSON file, from which extract the value I need?
    So far I tried the web scenarios and while succesful to log in and send the request, I see no way to actually extract the value I need and use it in a trigger.
    Thanks in advance!
  • LenR
    • Sep 2009
    • 1010
    Maybe this post https://www.zabbix.com/forum/zabbix-...-scenario-step
    I got several hits searching for "zabbix extract json from web" if that one doesn't work.
    • Singularity
      • Aug 2020
      • 81
      One of the options is create a shell script and use curl to get the json response. Execute the shell script from zabbix. Now you can simply create dependent items with pre-processing as Json Path.
