help in order to save space on VM
  • JaxMinitoring
    • Jan 2020
    • 38
    Good evening everyone, I need to free up as much space as possible on the zabbix server. I have a lot of items etc but every two months I find myself increasing space on the vm. the point is that I would like to understand how to clean old deleted data. despite zabbix housekeeper etc. unfortunately I do not come out
    Any suggest?
    thanks in advanced
  • LenR
    • Sep 2009
    • 1011
    mysql, at least innodb, doesn't free space from deleted items. See https://www.percona.com/blog/2013/09...r_table-is-on/
    If you have file-per-table, then OPTIMIZE TABLE will reduce disk usage.
    I've found that the easiest way combines file-per-table and the Zabbix partitioning methods. This, if it's current: https://zabbix.org/wiki/Docs/howto/mysql_partitioning
    • JaxMinitoring
      • Jan 2020
      • 38
      thnks a lot for your reply
