ssh checks for Disk space
  • athreyavc
    • Aug 2007
    • 13
    Hi, I am currently using zabbix for monitoring a QNAP device. QNAP doesn't have any DISK IO Mibs, from where I can get the IOPs data.
    I am planning to write a shell script which can use SAR or iostat to get some data
    From SAR, I get data like this
    dev253-1 ,0.24
    dev253-2 ,1.04
    dev253-3 ,1.04
    dev253-4 ,0.00
    dev253-5 ,0.00
    dev253-6 ,1.04
    How to use it in zabbix ?
    I don't want to write individual items for each device.
    Thanks and Regards,
    A
  • jan.garaj
    • Jan 2010
    • 506
    Use some existing zabbix iostat template from https://github.com/zabbix/zabbix-community-repos
    • athreyavc
      • Aug 2007
      • 13
      Thanks for the response. I will try them and update you.
      Best Regards,
      A
