fping failed: "/usr/sbin/fping6: can't create raw socket (must run as root?) : Operat
  • carlitos_30
    • Feb 2015
    Hello.
    I was looking for a NMS and Google lead me to Zabbix. I downloaded the VM image.
    When I try to create a ping item I get the following message:
    "fping failed: "/usr/sbin/fping6: can't create raw socket (must run as root?) : Operation not permitted"
    I applied the commands:
    chown root:zabbix /usr/sbin/fping
    chmod 4710 /usr/sbin/fping
    chown root:zabbix /usr/sbin/fping6
    chmod 4710 /usr/sbin/fping6
    then reboot the VM.
    The damned thing still doesn't work.
    It's hard to understand a supossed professional level software comes with this kind of details.
    "Focus in the user" I read in someplace.
  • scdickey
    • Feb 2015
    • 11
    i experienced the same thing. I think what may have fixed it is uncommenting the 2 lines:
    # Mandatory: no
    # Default:
    FpingLocation=/usr/sbin/fping
    ### Option: Fping6Location
    # Location of fping6.
    # Make sure that fping6 binary has root ownership and SUID flag set.
    # Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    Fping6Location=/usr/sbin/fping6
    located in the zabbix-server.conf in the /etc/zabbix folder
    and then restarting the server...
    • carlitos_30
      • Feb 2015
      Solved
      Thank you very much scdickey. Your solution worked to me. I think this post should be sticked.
      Thanks again!
      • msantangelo
        • Feb 2015
        • 19
        Hmm. Curious.
        I just deployed the OVF template for Zabbix and was having this same exact issue.
        I did the chown/chmod commands as per the manual and it didn't fix anything. I came across this and did the fix, but now I'm getting:
        " At least one of '/usr/sbin/fping', '/usr/sbin/fping6' must exist. Both are missing in the system. "
        Any thoughts?
        Those files are DEFINITELY there. I just tried to use them:
        > sudo /usr/sbin/fping anip
        >> anip is alive
        Any ideas?
        # Mandatory: no
        # Default:
        # Mandatory: no
        # Default:
        • tchjts1
          • May 2008
          • 1605
          Originally posted by msantangelo
          Hmm. Curious.
          Any thoughts?
          >> anip is alive
          Any ideas?
          Can you show the output of these commands?
          # which fping
          /usr/sbin/fping
          # ls -l /usr/sbin/fping
          -rws--x---. 1 root zabbix 37079 Nov 10 2010 /usr/sbin/fping
          And then show the section of your zabbix_server.conf file that shows the fping parameter:
          # Mandatory: no
          # Default:
          • msantangelo
            • Feb 2015
            • 19
            I actually figured it out this afternoon! On the 2.4 OVF, the server instance runs as user zabbixs, in group zabbixs. The fping and fping6 in /usr/sbin had permissions granted to zabbix. This was fixed by either changing fping and fping6 group to zabbixs (favorable) or adding zabbixs to group zabbix (not so favorable)
            In the 2.2 OVF, the user zabbix is not in group zabbix, which is fixed with usermod -a G zabbix zabbix.
            Weird.
            # which fping
            /usr/sbin/fping
            # Mandatory: no
            # Default:
            • dirckcopeland
              • Oct 2013
              • 50
              msantangelo,
              That fixed it for me to. The command actually has a "-" before the G:
              usermod -a -G zabbix zabbix
              • konomoujorge
                • May 2015
                # Mandatory: no
                # Default:
                # Mandatory: no
                # Default:
                uncommented FpingLocation and FpingLocation, and restarting the service returns an error and could not start zabbix agent service.
                Any ideas?
                • msantangelo
                  • Feb 2015
                  • 19
                  What's your zabbix error log show? Maybe you entered some text elsewhere in the file that is gumming up the works.
                  • tchjts1
                    • May 2008
                    • 1605
                    Any ideas?
                    Uncommenting those lines doesn't do anything, as those are the default settings. Zabbix will use the defaults regardless of being commented or not.
                    The only difference would be if you changed something on that line and uncommented it.
                    • konomoujorge
                      • May 2015
                      Thanks tchjts1.
                      Manage to get fping trigger working, without uncommented any lines in conf. file.
                      Here's another thread that followed and helps.
                      • lkolluru
                        • Dec 2015
                        unable to start zabbix on CentoOS 7
                        [root@Centos70x64 ~]# systemctl start zabbix-server
                        Job for zabbix-server.service failed. See 'systemctl status zabbix-server.service' and 'journalctl -xn' for details.
                        [root@Centos70x64 ~]# journalctl -xn
                        -- Logs begin at Wed 2015-12-16 05:24:24 EST, end at Wed 2015-12-16 06:41:49 EST. --
                        Dec 16 06:41:49 Centos70x64 zabbix_server[10887]: zabbix_server [10887]: cannot run as root!
                        Dec 16 06:41:49 Centos70x64 systemd[1]: zabbix-server.service: control process exited, code=exited status=1
                        Dec 16 06:41:49 Centos70x64 systemd[1]: Failed to start Zabbix Server.
                        -- Subject: Unit zabbix-server.service has failed
                        -- Defined-By: systemd
                        -- Support: http://lists.freedesktop.org/mailman.../systemd-devel
                        -- Unit zabbix-server.service has failed.
                        -- The result is failed.
                        Dec 16 06:41:49 Centos70x64 systemd[1]: Unit zabbix-server.service entered failed state.
                        Dec 16 06:41:49 Centos70x64 systemd[1]: zabbix-server.service holdoff time over, scheduling restart.
                        Dec 16 06:41:49 Centos70x64 systemd[1]: Stopping Zabbix Server...
                        -- Subject: Unit zabbix-server.service has begun shutting down
                        -- Unit zabbix-server.service has begun shutting down.
                        Dec 16 06:41:49 Centos70x64 systemd[1]: Starting Zabbix Server...
                        -- Subject: Unit zabbix-server.service has begun with start-up
                        -- Unit zabbix-server.service has begun starting up.
                        Dec 16 06:41:49 Centos70x64 systemd[1]: zabbix-server.service start request repeated too quickly, refusing to start.
                        • zerono
                          • Oct 2021
                          as https://ip-connection.blogspot.com/2...cket-must.html
                          chown root:zabbix /usr/bin/fping
                          chmod 710 /usr/bin/fping
                          chmod ug+s /usr/bin/fping
                          • RandyS
                            • Nov 2014
                            Another thing to consider:
                            Did you disable support for IPV 6 on your server? Thank you all for your help - this thread lead me to success on that note.
                            [root@~]# grep fping6 /etc/zabbix/zabbix_server.conf
                            #ORIG## Fping6Location=/usr/sbin/fping6
                            #NEXT LINE FAKED OUT BECAUSE IPV6 IS DISABLED ON THIS RHEL 8 SYSTEM##Fping6Location=/usr/sbin/fping6
                            [root@~]#
                            • sajihome
                              • Dec 2022
                              The below Steps worked for me
                              Give Permission
                              Edit in Zabbix Config
                              Enable IPv6 in Ubuntu​
                              Good luck
