Dashboard Widget Graph, will it show Triggers?
  • elmorekevin
    • Feb 2018
    • 15
    It seems like the new Graph style has lots of options, but I cannot get it to show Triggers that are set for the items selected.
    The classic graph (based on an item's templated graph) has options to show triggers and a dashed line, but this feature does not seem to be available for the new graph style.
    Am I missing something, or should this be a feature request?/
    Thanks,
    Kevin
  • ripperSK
    • Jul 2019
    • 42
    looking at the non classic graph display options I agree with you that it does not visualize trigger threshold.
    you can probably file a feature request - or maybe someone else on this forum knows a workaround / way to display the threshold.
    I personally assume that non classic graphs should be used to combine visualization of multiple items optionally from multiple hosts - making trigger threshold visualization difficult.
    but that's all just my opinion and maybe I'm wrong...
    • elmorekevin
      • Feb 2018
      • 15
      splitek What are you saying is working if you have simple trigger?
      ripperSK I would say non-classic graphs should still be able to show multiple triggers. If they can show Problems as vertical lines for multiple items, then that would be just as difficult to visualize, so why not Triggers too?
      I'll work on making a feature request.
      • elmorekevin
        • Feb 2018
        • 15
        That makes sense to me now.
        Please upvote/reply to the suggestion post linked here.
        Thanks All,
        Kevin
        Dashboard Widget Graph (new style): Can show problems, but can't show triggers Dashboard Widget Graph (classic): Can show triggers, but can't show problems I would love to be able to show either or both Problems or Triggers on any type of graph in Zabbix. Thanks, Kevin
        • elmorekevin
          • Feb 2018
          • 15
          Thank you for the suggestion. I made it here:
