check list
  • JaxMinitoring
    • Jan 2020
    • 38
    check list
    Good evening everyone I would like to ask if there are any checklists for the administration of the zabbix server.
    I ask this to understand if every two weeks there are checks or actions that can be implemented on the server side to free up space and make necessary checks.
    Has anyone of you implemented a monitoring with timed actions to avoid getting saturated with space on the server?
    my situation is for expample this:
    h20.00 - DISK CRITICAL - free space: / 52624 MB (10% inode=99%)
    h21.00 - DISK CRITICAL - free space: / 52554 MB (10% inode=99%)
    h22.00 - DISK CRITICAL - free space: / 52480 MB (10% inode=99%)
    There is something that keeps eating up space every hour
    I give an example of reference for the check list:
    zabbix check
    1.manually run the hausekeeper
    2. restart services example. 1-2-3 service etc.
    3 user @ host- $ mysql -f zabbix <cleanup.sql or user @ host- $ ./cleanup.sh user @ host- $ ./cleanup.sh ./zbx_db_info.cnf
    ecc.
    let me know is someone can help me in order ti fix and create manually task for make correct maintenace on server.
    thanks in advanced to all
  • JaxMinitoring
    • Jan 2020
    • 38
    Any suggestion?
    • isaqueprofeta
      • Aug 2020
      • 154
      Readout about the housekeeping process, you can work out with some good custom policies on your items get interval and history retention.
      Old but gold: http://www.quadrata.it/zabbix-and-ho...ouble-story-2/
      • JaxMinitoring
        • Jan 2020
        • 38
        thanks for the reply
