Hi all,
so I have been doing a lot of reading and was pretty sure this feature was working 4.X before I upgraded to 5.X
(Names of vars changed from real world)
I have a trigger expression as follows
{server1:my_custom_check.last(#1)} <> {server1:my_custom_check.last.last(#2)}
For this example my_custom_check returns a numeric ranging from 0 to 10,000
In the Trigger name I have the following
Server count change from {ITEM.LASTVALUE2} to {ITEM.LASTVALUE1}
What I expect to get when the trigger creates a problem is something similar to
Server count change from 100 to 166
What I get is
Server count change from 166 to 166
so the current value triggering the expression.
This is according to the docs the correct result I believe?
What I want to know is HOW do I get the value before the triggering value, so I get this expected result
(assuming server1:my_custom_check.last(#1)} = 166 and server1:my_custom_check.last(#2) = 100
Trigger name combinations tried so far
Server count change from {ITEM.LASTVALUE2} to {ITEM.VALUE1}
AND
Server count change from {ITEM.VALUE2} to {ITEM.VALUE1}
help/guidance would be appreciated
What I get is
AND
