Evaluating Item keys in Trigger descriptions.
  • h_y_i_e_n
    • Jun 2020
    How can I evaluate an item key inside a trigger description?
    eg. trigger prototype from LLD rule:
    With the above, the item isnt evaluated, simply copied as is.
  • Semiadmin
    • Oct 2014
    • 1626
    In this case, just use macro {ITEM.VALUE1}. In general case, you try to use macro {host:key.func(param)}, but it doesn't support in trigger description.
