Zabbix Dashboard Filter Problems
  • fabian.fasser
    • Jun 2018
    Hi
    I try to filter in the "problems by severity" widget with text. But I can only add one filter. Is it possible to do it with regex or something similar?
    In the Problem field I want to add something like: "WS: Windows; WS: Citrix"
    Click image for larger version  Name:	zabbix.PNG Views:	0 Size:	23.0 KB ID:	407675
    Fabian
  • isaqueprofeta
    • Aug 2020
    • 154
    Try working with Tags, instead of Trigger Name.
    • fabian.fasser
      • Jun 2018
      Maybe that works for Widget Type "Problems" but not for "Problem by severity". Any other solution?
