Having a weird issue going on with DBforBIX items.
We have a query set to a period of 5 minutes in DBforBIX. However, if we look in the Zabbix GUI, we see that the item is collected multiple times during that polling period (maybe within a second of themselves).
Example - we will see a value for <QUERY> at 13:01:00 and then again at 13:01:01 in the latest data screen although in DBforBIX it only shows the query was ran once.
This appears to be causing the triggers, set off those values, to fire multiple times and generating emails each time.
Anyone else seen this behavior, and what was your solution to the problem?
Let me know if you need to see any configuration data or logs.
