snmptt.log - SNMP athentication failure
  • manosnms
    • Jun 2020
    • 52
    I keep receiving at snmptt.log the error message .1.3.6.1.6.3.1.1.5.5 Normal "Status Events" UNKNOWN - SNMP athentication failure
    does anybody knows why I am getting this?
    Zabbix 5.0.2
    snmptt-1.4.2-1
    thank you
  • isaqueprofeta
    • Aug 2020
    • 154
    Look if you are using communities, commonly in intranet you don't need them for authentication on traps.
    • manosnms
      • Jun 2020
      • 52
      In case I have done something wrong. at which file should I put the community string? We do use communities.
      Thank you
      • Hamardaban
        • May 2019
        • 2713
        Most likely, some device in the network sends traps that the wrong credentials were used when accessing it over SNMP.
        Try configuring snmptt to log the ip address of this trap sender.
        Then figure out who and why is accessing this device and configure the device and NMS to use the same credentials and SNMP versions.
        • manosnms
          • Jun 2020
          • 52
          Great. thanks
