Zabbix one trigger for all web scenario
  • crocoitsupp
    • Aug 2020
    Is there any way to create one trigger for all web scenarios to send telegram message when one of it will fail or resolve?
    And is it possible to send telegram message by host name?
    Thank you
  • isaqueprofeta
    • Aug 2020
    • 154
    After creating your scenarios you can find some itens with web.* keys in trigger creation, use them to create your triggers and them create a action with condition for any trigger send a message. I didn't understand your question about "send telegram message by host name".
    Image for reference about web.* keys in trigger creation:
Name:	Captura de tela de 2020-08-26 13-29-15.png
    • crocoitsupp
      • Aug 2020
      I mean if it is possible to create just one trigger to check all web scenario, so if one of scenario's status isn't "OK" it will send telegram message with a name of specific scenario which failed.
      I don't want to create trigger for all of scenario.
      • isaqueprofeta
        • Aug 2020
        • 154
        The only idea that comes to my mind is creating one scenario with all others as steps then...
