Log of all triggers fired
  • tw13
    • Aug 2020
    Is there a location for all triggers that have fired? I can't find one and I can't find a post here for it.
    My workaround was to create an action to add {DATE}{TIME}{TRIGGER.NAME} to a log file whenever a trigger fires. The issue we are having is that we want all logs in the log file but only single logs on the dashboard.
    So we can set "PROBLEM event generation mode" to multiple so the log catches everything, but we don't need 50 alarms telling us the same thing on the dashboard.
    Does anyone know of a way to do this?
  • isaqueprofeta
    • Aug 2020
    • 154
    A Trigger doesn't fire itself, it fires an event.
    Go to Monitoring -> Problems and then filter Show as History, then filter the Host/Trigger in the matching filter field, be careful to adjust the Time Range in the Top Left.
    Reference:
Name:	Captura de tela de 2020-08-27 17-24-18.png
    • tw13
      • Aug 2020
      Reference:
      THanks, for replying. Is there a way to get this information in log file format?
      • isaqueprofeta
        • Aug 2020
        • 154
        Two ways:
        Use Zabbix API to extract it (three resources you need to search and make your implementation):Use the Zabbix SNMP gateway project:
