Problem Trigger filter text (10)
  • cb01
    • Aug 2020
    I have a trigger, the trigger should trigger if inside the line there is a (10) not if 10 .
    {TEST PC:log[c:\Fanwin\ALARM.txt,,,,,,].regexp("(10)")}=1
    At the moment the trigger work if a 10 is detected. Can anyone tell the correct syntax to do that?
  • Hamardaban
    • May 2019
    • 2714
    \(10\)
    • cb01
      • Aug 2020
      That isn't working with \(10\) .....
