Web Test - Step Name/Number Macro
  • Clontarf[X]
    • Jan 2017
    • 80
    Just checking before I raise a feature request; is there a macro or other method to display the name of the failed web test step? Specifically the step, not the item.
  • isaqueprofeta
    • Aug 2020
    • 154
    Yes there is: web.test.fail[Scenario]
    https://www.zabbix.com/documentation...nitoring/items
    Failed step of scenario <Scenario> This item will display the number of the step that failed on the scenario. If all steps are executed successfully, 0 is returned.
    Item key: web.test.fail[Scenario]
    Type: Numeric(unsigned)
    • Clontarf[X]
      • Jan 2017
      • 80
      Thanks but I was after a macro, not an item And it looks like that only returns the step number and not the step name.
