Trigger dependent on x items
  • tester777
    • Aug 2020
    • 9
    Hi there.
    One year ago a, now ex, colleague of mine, handed over Zabbix Administration to me. I really like it more than opennms, scom and so on.
    And was able to solve most of my problems myself.
    However now I have the following problem where I need some guidance.
    I have a discovery rule that creates multiple items. Also items to get the size of multiple databases as a float value in mb with for example with key dic.server.database.db1.geitems.filesize
    Now I want to create a trigger that triggers when one of the dbs has a bigger size than 60000.00 (60GB).
    As far as I could read with Google it is not possible to create a trigger with wildcard in item expression for example:
    dic.server.database.*.geitems.filesize
    But how could I go ahead?
    Thanks a lot
    David
  • isaqueprofeta
    • Aug 2020
    • 154
    Create in your Discovery Rule a Trigger Prototype for one of DBS, then all DBS discovered will have its own trigger.
