Traffic Volume
  • tabo8226
    • Aug 2020
    Traffic Volume
    Hello guys, I'm using zabbix to monitor several network devices (router, switches, etc)
    It counts traffic very well, but I'm interested if it's possible to count traffic volume? For example from 09:00-10:00 I consumed 100gb traffic, not only speed.
    I saw several topics but they are about counting with agents and I'm using SNMP on my devices.
    Thank you!
  • isaqueprofeta
    • Aug 2020
    • 154
    Since you already have the deltas (the current usage per time of bandwidth), you want to sum this all up. Try creating a calculated item with a function like sum with a time_shift.
    If you want this dynamically, you're going to want to use something like Grafana, since it transforms data on-the-fly.
    • tabo8226
      • Aug 2020
      Hello, thanks for answer, I saw several topics with answer like that but I can't make it to work...
      See attachment, it's from CACTI, can I make somehow similar with it? I tried several method but it won't work as I want.
      with sum ( SUM(INTERFACE,1M) ) I'm getting all traffic summed for 1 month.
      • isaqueprofeta
        • Aug 2020
        • 154
        In Zabbix, if you know the steps, you can look at the docs, here's the stepsIn Grafana, after setting up the interfaces, use the sum() in functions options, and it'll sum all time queries that you have in the time picker.
        • tabo8226
          • Aug 2020
          Thank you, I'll try that!
          • zippoalice
            • Apr 2021
            ciao, sei poi riuscito?
