Execute Item when created
  • d2718nis
    • Oct 2018
    Hello. I'll try to describe the problem as simple as possible:
    - You have a Template with one enabled Item with 1 day delay
    - You create a Host linked to this Template, Item copied to the Host
    - The copied Item will be executed only after 1 day, right?
    Is there a setting or any way to execute all enabled Items when added? Thanks.
  • isaqueprofeta
    • Aug 2020
    • 154
    If your templates have Discoveries, first "Check Now" the Discoveries and them "Check Now" all the items.
    You can do it massively look at https://www.zabbix.com/documentation...tems/check_now
