Monitoring two or more asterisk running
  • mduduzi
    • Aug 2014
    Asterisk Alerts On Zabbix
    Good Day
    i hope i`m on the correct forum i have been given a task to setup an monitoring system on zabbix for asterisk to minitor if more than one asterisk is running and so far i manage to check for only one process
    UserParameter=ae.asterisk.running, sudo ps -ef | grep /usr/sbin/asterisk | grep -v grep | wc -l
    now i need to be able to get an alert if more than 1 asterisk is running
  • Jason
    • Nov 2007
    • 431
    Look at proc.num item on https://www.zabbix.com/documentation...s/zabbix_agent That should do what you need.
