Add field to "STATUS OF TRIGGERS"
  • Strategist
    • Sep 2013
    • 54
    Hello, can you help me to find a simple solution, please.
    I want display the status of triggers in the "Screen", but in a slightly updated form. In this form add an additional field: "IP", and remove the "last modified" to be like this:
    STATUS OF TRIGGERS
    | Host | IP | Issue| Age | Info | Ack| Actions |
    I suspect that the built-in functionality does not allow to do so, but if it's possible, it would be very good, the only thing that I found - a solution through the API: https://www.zabbix.com/forum/showthr...status+trigger - but it's not quite.
    It would be great to save by default the usual form, and in particular sreens display changed form.
    Thank you very much for your help.
